Window Type Schedule
Is there a way to create a window type schedule that only shows one of each window type? Would want output scale to be 1"=1'.
yes
Steve wrote:
yes
Now the question will be "How?"
You will need to not use the window "ID" in the fields of your schedule if you have unique IDs for each window.
If similar windows have the same IDs then you can still use it.
Then in the schedule settings tick the box for "Show uniform entries as a single entry".
The trick is you only want to use fields that show only what is unique about the windows - size, type, materials, etc.
The downside of this is if you do have unique IDs for your windows and you want to show one window and all the unique IDs for that window then you can't do this automatically.
You will need to create a custom text field and type them in yourself.
