KeesW
Windows 7
Has anybod tried running Archicad 12 on the beta release versin of Windows 7? If so, how did it go?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
32 Replies 32
Josh Osborne
Sam thing here. ArchiCAD still works fine though, so I didn't worry about it. If you don't install the visual C++ redistrib on XP or Vista, ArchiCAD won't even start, so seeing as it works on 7, I assumed that it's already there.
Josh Osborne - Graphisoft
fixed my prob it was all a clash with a broken adobie Acrobat pro..
sorry for messing up the topic.
Josh Osborne
Just tried AC12 on the Windows 7 RC and everything still works fine.
Seems significantly faster than the beta too.
Erika Epstein
Henry, do you know if you can go from XP direct to 7?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Josh Osborne
You can't in the RC and you won't be able to in the Final release either.
Upgrading is only supported from Vista.
I've never known an OS upgrade to go well(except in Linux), so I never do them myself. I usually reformat my Windows machines at least once very six months to clean out all the rubbish anyway.
Erika Epstein
Thanks Henry. I'll have to query Dell at some point about whether this machine is up to the 7 OS change. It''s only a year old and I was told I could install Vista, but chose not to.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Last week I read an article which said that there will be a killer feature in Windows 7: you can get Windows XP in it. It was something like that for an additional fee they give you Windows XP which will be able to run in Windows 7 or something like that.
So many people may upgrade to Windows 7 and then keep using Windows XP within it.
Pete
That sounds like a great idea! Way to go Microsoft! Where do I bend ov... I mean sign up for this?
I sure glad that, after 24 years on PC, I switched to Mac.
Pete Read
ArchiCAD 12; Artlantis Studio 2
MacBook Pro 2.4 Core2Duo, 2GB, OSX(10.5) and XPpro(SP3)
Josh Osborne
So far as I know, the "XP Mode" is going to be a free download for Ultimate and Business versions.
I really don't see what you would want it for though.
I give you an example: I could not install ArchiCAD 9 on Vista. However, there is a project we started in 2004 which we worked on in ArchiCAD 9. There were still modifications on it but it was not worth the effort to migrate it to 11 or 12. Also, Amyuni PDF driver does not work on Vista so you cant use in in AC 9 on Vista.
If this XP thing is true in Windows 7 then it is probable that previous versions of ArchiCAD will run well in that XP module. Which can be important to some (or many?) people.
