2005-09-08 04:29 AM
2005-09-13 03:31 PM
laszlonagy wrote:Yes, this is what I suspected. I was just hoping that there might be a way that I had ovelooked. I have resorted to creating light and vent values for each of my windows with a formula based on how the manufacturer calculates the values... I then place the values into parameters that I call into additional parameters of an interactive schedule...its sort of cumbersome and not without other problems.
...I think if this is possible, it is possible only with API.
2005-09-13 03:33 PM
Dan wrote:I would think you would have to use the Interactive Scheduler or a Listing to get that information straight from the Doors/Windows/Louvers themselves. I believe going through the Zone to get these settings would only give you the size of the wall opening (WALLHOLE for you GDL types. Even then, the object itself would need some way of distinguishing glass area from frame area.
Laszlonagy,
Nice example...I wonder how you might extend this to use the zone tool in creating Light and Vent shedules??? The values returned seem to give the overall opening surface...how might one get it to display only the glass surface area??? And since different types of windows have different operations, i.e., a fixed window provides no vent where as a single hung window might provide close to 50% of the surface area,etc.,etc.
Any thoughts?
2005-09-13 03:54 PM
TomWaltz wrote:Tom,
2005-09-13 08:35 PM
2005-09-13 09:00 PM
Electric wrote:Guys, you should make a wish for this item.
Thank you Laszlonagy for your great help.
I´m also trying to create a Light and Vent shedules with IS like Dan Kunschik. I can´t get it!!
Please Graphisoft, let Zones read glass surfaces from doors and windows. That shouldn't be that difficult. Light/Vent shedules is a very important issue.
BTW, zones can´t read "W bottom hung" surface. Seems to be a bug with it's GDL script.
2005-09-13 11:24 PM
laszlonagy wrote:Laszlo,
I can imagine there could be new GDL Global variables implemented which could solve this.
2005-09-14 12:05 AM
2005-09-14 01:21 AM
