Ernest Atanasiu
Zone finish for walls, floors and ceiling
Hello
Is it possible to define the default finish for zones? I want to schedule a lot of zones with different custom finishes and it would be a lot easier to choose from a predefined list.
I am aware of the CUSTOM option, it would be nice if the values could be stored somewhere.
Thank you.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
10 Replies 10
Erwin Edel
I should point out that for whatever reason these things only seem to work with zones that have automatic boundaries and are trimmed to roofs etc
I don't have a lot of experience with this amount of model detail, BIM-ness, the bulk of our work is private clients who tend to not know what they want on the floors and walls etc until we've already started construction
This makes quantity take off a lot more generic or less defined if you will.
But I did use the new surface schedule to moderate succes for extracting surface areas for the dutch standard energy evaluation calculation needed for permits by creating morphs using the simplified dimensioning required (breaking down the model to basic shapes) with specific surfaces assigned according to the 'energy loss surfaces'.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
