Zones viewed in Bluebeam Revu
I hope this is the best place to post this inquiry...
Currently using AC20 & publishing / saving PDF files from layouts, marquee model views, etc... When zones are used, the set area shows up in Revu as a purple transparent fill. These "fill" areas do not get reflected in any hard copy prints from Revu, only on the screen view within the program.
Also, if the PDF file created by ArchiCAD is opened with a different program, Acrobat for example, the "fills" do not get displayed in that viewer.
Has anyone else had this issue arise, and is there a setting within AC20 (or maybe in Revu) to have it not show up in Revu? It's more of an inconvenience than a major problem, but when a client sees them, they get confused. Thank you.
Turn off the space setting in Bluebeam
12 REPLIES 12
So very much appreciated!
Thank you.
You're very welcome, it caught me out too.
I'm having the same problem, but I can't find in Bluebeam Revu for Mac where this space setting is to turn off? Thanks!
Right click on right column > Show > Spaces) to view the office space.
This is for windows, sorry not sure about Mac
Yea...unfortunately Revu for Mac doesn't have all of the features yet that Windows does. So my options on that Show dropdown doesn't include Spaces. Bummer. What's the alternative - turning off the Zoning layer, and adding in text for Room Name/Number before saving as a PDF? Superb.
I would think there must be an option to turn them off if they are on.
try a google search or contact your re seller.
Brad Elliott
So now this inconvenience has become a big problem for us. Our jurisdictions Building Department is now using Bluebeam to review electronic building permit submittals. And they tell us that Bluebeam is making a big push into the permit review market. We do not have the ability to tell the county to modify their program by turning off spaces on all their computers so they can read our documents and they absolutely don't want to see the zones shaded in on our drawings. We're on AC 21 and they are both owned by the same company. This needs to be fixed.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
You should contact Bluebeam about this and tell them.
