archicad 16 google earth connection
is the google earth connection available for archicad 16 yet? thanks
27 REPLIES 27
Achille Pavlidis
Still not available...
any news GS?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
I got the info from GS that they are planning to release it next week.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
The GEC Add-on for ArchiCAD 16 is now available on graphisoft.com: http://www.graphisoft.com/products/archicad/addons/google_earth/ge_earth_connections_download.html
Note: if you cannot see the updated site, please clear the cache of your browser
Katalin Takacs
Achille Pavlidis
Thank you!
Achille wrote:
Thank you!
hi, can anyone tell me how to get the google earth terrain into archicad 16 - 64 bit ? is there a tutorial somewhere ? please help. - without using ac14 32bit .... ?
Dwight
Once you've installed the connection at the address below, go here for full instructions, not that I have been able to make it work.
Dwight Atkinson
TMA_80
Seems to me that the technical issue with GE (as with the 15th version) is still present.
AC12_27 |Win11_64bit|
Dwight
Can anyone make this work?
Dwight Atkinson
Terrain into AC has to be in 32 bit mode on Windows only. To get the terrain in 64 bit requires lots vs one step, including a free copy of SketchUp... at least hopefully it will stay free even though Google doesn't own it any longer.
You bring the GE snapshot into SketchUp by having both open and capturing the terrain in SU. Then save the file as skp, and open the skp in 64 bit AC with the GE connection add-on which allows the skp to be converted to a GDL object. Whew.
Exporting the model to GE on Mac (64) - doesn't work properly because Project North is ignored ... the export is done as if Project North is set to 90 degrees regardless of the setting. Or, at least in my project with North is 135 degrees, it is ignored.
(Also very hard to get the project anchors/coords set on Mac so that the export appears in GE at exactly the right place rather than a few feet away.)
