2018-02-22 09:31 PM
2018-02-23 02:33 AM
2018-02-24 07:00 AM
2018-02-25 08:53 PM
2018-03-04 10:04 PM
2018-03-07 10:39 AM
2018-03-07 10:42 AM
INR wrote:We're correcting that – the tolerances were set far too tight.
So for those that were interested, the walls were approx 1 hundredth of a degree out causing the error
2018-03-08 12:44 AM
2018-03-08 02:23 PM
Rogerdodge wrote:We're working on something that should solve that issue. Best approach for feature requests is to contact our support team – they add it to development database so it can be tracked from specification to release.
Hi Ralph, if you are doing some work on the bracing tool I have a request.
When all the parameters have been input, such as dimensions, bracing set etc. can they be saved?
Quite often I have to go back out the DBX to get a dimension or other for the bracing input, then when i re-open i have to input all of the info again!
2018-03-08 09:29 PM
