calculate SF of slab?
Is there a way to calculate the square footages of a free standing slab? I have a driveway that has an irregular shape (it has a couple curved edges) making it difficult to simply multiply length by width. I tried to use the zone tool but it requires the area to be "enclosed by boundary elements," and apparently a slab doesn't fulfill this requirement...
thanks for your help.
5 REPLIES 5
Erika Epstein
Select the driveway,
Open your Element Information Palette (Windows> Palettes> Element Information)
Under Information Content, the 3rd button from the left will give you the Area on Plan.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Use a Fill that has the "Show Area Text" checked. Alternatively you can use a Zone with Manual Construction Method, or just Magic Wand (Hold Space bar down) the Fill (or group of lines) to create the Zone.
See attached.
The Element Information palette is very often overlooked. (It just came up a couple of days ago with regards to determining the length, with one click, of an arbitrary poly-line.)
It is one of half a dozen ways of retrieving model information - usually about a single element. (No substitute for schedules, etc. of course, particularly since cumulative math is not performed here. But, Element Info offers the fastest method if all one wants is a quick answer about one element.)
Here's a screenshot of that same slab with all of the information that can be retrieved about it displayed - along with the flyout menu that lets you save the data or print it. (You can also select and copy/paste.)
cool, thanks guys. I was able to get the SF using both the manual zone method and the element information menu.
