door schedule, door numbers not appearing in sequence
i am working on a door schedule in archicad 13, on a cad file which has been produced by some of the worst cad users i have ever experienced, i have the wonderful job of sorting it all out.
the door schedule is an utter mess, and for some reason the door numbers are not appearing in the schedule in numerical and alphabetical order?
You will want to go into the "scheme settings" for the schedule.
Then in the "fields" section use the ordering arrows (ascending/descending) to arrange the order of the output.
The attached example isn't a window schedule but it is the same principle.
thanks, that has worked perfect
