‎2016-11-29 01:55 AM
‎2016-11-29 01:57 AM
‎2016-11-29 09:11 PM
jacobidiego wrote:I don't think you can do what you want with AC schedules.
a) Can you help me to get the above behavior?
jacobidiego wrote:This is the better option. AC will let you list everything you need, but when it comes to filtering, arranging, grouping, etc... the data, a spreadsheet editor will get you there sooner. The way to get this to work is to set up a publisher set for your schedules. Save either as .xls or .txt and link the information (don't just open and edit the resulting files). Should you make any changes, you just click publish again and wait for excel (in this case) to update everything.
b) Is it possible to use Excel and Pivot tables, to summarize this data? ¿Can it be connected to an AC internal database?
‎2016-12-02 01:06 PM
‎2016-12-08 12:04 PM
