hairlines in autocad
Is there a way that when drawings are saved as in autocad format (2005)all lines in the translated drawing are hairlines? I click off true line weight on screen view options, I used all available translators, I searched the forum. But I cant fix this. Please help
14 Replies 14
Answering my own question.
1.Open the translated drawing in autocad
2.write the command convertpstyles
3.select all lines, change their properties (command:change)
4.Change their lineweight properties to 0
5. You may have to do these last 2 steps several times to make sure you convert all the lines. (If some are nested in blocks they should be exploded)
I hope theres an easier way
Eduardo Rolon
On step 3 instead of selecting all lines with the mouse, type ALL and press return this will select all the lines.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Dennis Lee
I have no problem getting hairlines, and here are my settings.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
EXCELENT! Thank you very much. Its a lot easier this way. Thats what I was looking for!
Im starting to use archicad 11
In translating drawings to autocad 2005 I cant click on the option "do not export archicad penweights" (It's greyed) to export drawings in hairlines to autocad 2005.
I tried different conversion methods even tried to create a new one without success.
This option worked perfectly on archicad 10. Meanwhile I have to translate back to archicad 10 and then to translate to autocad to export drawings in hairlines. I dont know if this is a bug
TomWaltz
Do you have "Show True Line Weights" turned on? I've found that Archicad reads that setting regardless of the translator options.
Tom Waltz
I tried both ways turning off true line weights and turning off bold cut lines. No sucess still. Thanks anyway
Andy Thomson
Mentor
No! It WILL work. Turn off the 'display only option' (BS), then the translator radio button becomes available - check it - save your settings, update placed drawings as needed - AC then does not export lineweights to modelspace. Works for me.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
Thanks for replying. I thought the Issue was forgotten. I don't understand your instructions: "Turn off display only option" Could you please clarify?
