help finding window location from schedule
I just created a window schedule using the NSC window schedule generator and it told me that I have 3 empty openings but they are not windows (ie. I cannot select them), they have given them a number in the schedule but I would like to delete them and cannot find them in plan or 3d (using select all windows). Is there another way to find these hidden openings by their ID number to delete them?
Thank you so much!
Eduardo Rolon
Use the Select in Floor Plan button
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
or use Find and Select with the information you have
AC29 US/INT -> AC08
another Moderator
Thanks, that's so obvious now.
WB
