help on creating a schedule for listing a specific matelial
hello,
i made a column footing with the mesh tool and applied the reinforced concrete material. this is not showing at the schedules quantities.
why that?
can i do something to fix it?
thanks , i apreciate any help
14 Replies 14
how can i create a schedule for listing "concrete" material for example?
i see that the " schedule" do not contin any mesh or morph objects . why that?
is there a way to add morph or mesh or obgects in the schedule settings and then the schedule calculate the materials of these objects?
thanks
is here someone from graphisot that can help?
or anyone to suggest where else to look for ?
This image should help.
Go into your schedule settings and have a play around.
Is the Mesh solid? Or there is only a skirt with no bottom?
What are the criteria you set and what are the fields to be listed?
You should also put your ArchiCAD vesrion and specs in your signature.
hi,
thanks for the reply.
the mesh is solid and created in AC17.
i noticed that the component schedules do not have the mesh and the morph at the critiria but the ellement schedules include the morph and mesh.
but i cant schedule a material quantity as "element schedule" for example "concrete " material that is used in columns and composites and slabs.
how can i do it?
thanks again!!
hi,
thanks !!
i tried that and it works, but can i add materials for a composite structure to this listing? how?
i tried it with a beam and a complex profile with one of the sub elements " concrete reinforced" and i couldnt make it work.
Component Schedules only schedule composites and complex profiled elements ... those elements that have 'skins' (the components).
You would use an Element Schedule to schedule your mesh quantities. It sounds like you did not set up your criteria correctly. Should be 'mesh OR slab OR beam' etc to get all of the footing elements... enclosed in parentheses... and then choose the concrete material.
Repeating Laszlo's question - please post a screenshot of your schedule criteria. I'm relatively certain that the problem is your choice of settings there.
hi,
please see the attached image.
still the quantities inside a composite structure not listed.
it seems that i cannot have material listing inside a composite if the schedule is "element " type AND i cannot have morphs and meshes material listed if the schedule is" element.
i think the only way is to have two schedules ...
please someone see the pictures and help.
thanks
