2017-12-23 09:34 AM
2018-01-03 06:53 PM
2018-01-05 05:49 AM
2018-01-05 06:34 AM
2018-01-05 08:45 AM
Link wrote:Hi,
There are plenty of RFAs there.
Try this one:https://bimobject.com/en-us/aosmith/product/aosmith-hd-tanks
Link.
2018-01-05 08:48 AM
2018-01-08 09:24 AM
2018-01-09 11:06 AM
2018-01-09 11:27 AM
2018-01-09 11:34 AM
Roopa wrote:An LCF file is an ARCHICAD library. You add that via the library manager and than the objects inside the library become available for your project.
Hi sir,
But this .lcf file is not importing. I used the same procedure as we import the bimobject to this. There it is not showing the file type as lcf, Its showing only the rfa file. So how to import lcf file.
Roopa wrote:Full editing of RVT elements inside ARCHICAD is not possible. They are created differently and behave differently. This only works for plain and simple conversions via IFC. The RVT/RFA add-in is not intended for that workflow. You receive static geometry. They appear as walls, but they don't behave like them.
Then the revit file we can't edit in AC like wall height and all. If I opened the settings it not using the ok button. its greyed!!!
SO is there any option to do the changes of revit file in AC. How?
Thank you.
2018-01-09 11:40 AM
Roopa wrote:The RVT file is Hotlinked - you can only place an RVT file via the Hotlink. You can't edit any Hotlink directly. If you no longer want it Hotlinked, you should embed (break) the Hotlink (therefore no longer linked to an external file). This is why the OK button is disabled.
...If I opened the settings it not using the ok button. its greyed!!!...
