2017-12-23 09:34 AM
2018-01-09 11:46 AM
2018-01-09 12:07 PM
James wrote:HI,Roopa wrote:The RVT file is Hotlinked - you can only place an RVT file via the Hotlink. You can't edit any Hotlink directly. If you no longer want it Hotlinked, you should embed (break) the Hotlink (therefore no longer linked to an external file). This is why the OK button is disabled.
...If I opened the settings it not using the ok button. its greyed!!!...
2018-01-09 12:10 PM
Roopa wrote:As described in the RVT/RFA documentation, content is not parametric (the geometry is fixed). Please make sure you read the documentation
Then we can edit the wall and other things it will be parametric?
Or only few parameters we can change?
2018-07-30 02:58 AM
2018-08-16 05:40 PM
2018-08-17 06:07 AM
redens wrote:The only way to get Revit file content into AC20 is via IFC, you will need to have file saved as IFC from Revit
Can someone direct me on how to import a Revit file into ArchiCAD 20?
2018-08-18 05:26 PM
2018-08-19 08:37 AM
