importing and exporting
I was working in both solidworks 2010 and Archicad 14 and I wanted to import a custom desk into my Archicad file. I first tried a simple import but the object was a 2-D drawing within the 3-D mode. How do I export a file from Solidworks into Archicad and have the object show up as a regular 3-D image???
Thank You,
Nick
3 Replies 3
Which of the following formats can Solidworks export into 3D data?
DWG, 3DS, SketchUp, IFC?
I solidworks can export DWG, DXF, and then some other files.
Which file type are you thinking about? the problem i was having was that solidworks would not export in 3Ds.
vfrontiers
In the FILE MENU / Under Libraries and Objects / there is a selection called OPEN GDL OBJECT... here you navigate to your DWG file and it will begin creating an Object for ArchiCAD...
When you save it... it will ask a couple of question (regular object, window, door) and where to save..
Then this object will need to be placed in your plan...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
