insert external dwg to its zero
Dwg file contains exact site location with wolrd coordinates.
I would like to insert it into archicad to its original location, not to archicad zero.
Thanks for the help
You really do not want to do this as any data may be very far from the origin which will lead to all sorts of issues, just do a search on this forum.
Ideally the project origin should be at the bottom left of the project / site and use the project location to set the coordinates for the zero
Regards
Scott
Erwin Edel
I generally don't have any problems inserting a DGW at origin on a worksheet.
If you get any problems you could keep the original working unit (most likely meters instead of mm), this scales the problem down by a factor 1000.
That said, the model is always on the origin to avoid the problems Scott refers to.
The location you set at Project Location (CTRL + W) is the real world location of your project origin. You might need to convert cartesian to GPS, depending on your local standards, to get an accurate lattitude/longtitude.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
