make a schedule showing both m2 and sqs
Hi all,
I have done a Google search and nothing is quite what I am after but i do apologize now if there is something similar on another thread. I am setting up a schedule for a builder for their marketing material to show the areas for dwelling and non dwelling (that part I can do) but it only shows either m2 OR sqs. I was wondering if there was a way that I can show both m2 and sqs in the schedule. In Australia, even though we are metric, we still get people using imperial sizing for house areas as the people looking to build now go by their friends or family who built years ago and know the squares of the house.
I have next to no experience with scripting so if that is the best way to do I will need my hand held so to speak.
I am using Archicad 16 if that helps
Thanks,
Jason
7 REPLIES 7
Unless the zone stamp itself supports additional units, vs those set in project preferences, there's no easy way to display both. You can script, as you mention... but if this is for marketing, the AC schedules are not really that attractive - so I'd suggest saving/publishing to Excel (or CSV) and calculating the other units in the spreadsheet where you can also provide more attractive formatting.
If you must have the schedule be live in AC itself, then you might "wake up" this thread by posting there:
http://archicad-talk.graphisoft.com/viewtopic.php?t=38108
It can't be done in the same schedule unless you have a zone stamp that has both parameters for m² and sqs.
But if you are getting the areas from fills in your plan you could save 2 views of your schedule and set the units in each to be what you require.
You would have 2 separate outputs of the schedule but that might be workable.
David Maudlin
Barry wrote:
But if you are getting the areas from fills in your plan you could save 2 views of your schedule and set the units in each to be what you require. You would have 2 separate outputs of the schedule but that might be workable.
I took a look at this, but it looks like the Schedule is getting the units from the Calculation Units & Rules Preference, not the Dimensioning Preference, so I don't see how this can be done in a single file.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I should have actually tested this rather than just typing.
Yes it uses the calculation units which aren't saved with a view rather than the dimension units which are.
Sorry if I have misled anyone.
I'll put my thinking cap back on.
David Maudlin
I think combining the Dimensioning and Calculation Units & Rules Preferences would help, there is also the case where Curtain Wall Doors can only be scheduled in decimal feet (not feet and inches) since their units come from the Calculation Units & Rules. It can be confusing.
Link
I agree David. I have just been scheduling wall skins to show how priority based connections affect wall surfaces and volumes. All linear measurements are in decimal feet. If they were in feet and inches they'd match all the dimensions in the rest of the project!
Link.
Thanks everyone for their thoughts.
I am trying to 'idiot proof' the scheduling. The people I work with are sales people. Not us special CAD using types The less they have to think about, the less I have to do in the long run.
I have noticed that the schedules are pretty basic and not very user friendly. The way we currently do is by text boxes with some lines. It looks ok considering how simply it is. I may just leave it how it is for now and let everyone work it out long ways and then work on scripting something over time.
Anyway, Merry Christmas to all and thanks again for the replies!!
