‎2009-01-13 01:05 PM
‎2009-02-01 09:39 AM
‎2009-03-18 07:44 PM
‎2009-03-24 11:31 AM
‎2009-03-24 02:19 PM
‎2009-03-24 03:06 PM
‎2009-03-24 03:15 PM
‎2009-03-24 03:40 PM
mariosmic wrote:That's a shame, as the spline was used to generate a swept profile. You can still edit the spline in C4D, provided you have the points. A trick is to store the spline points in a separate ASCII-file and reload it again. But with many splines, this will be painful. And you have to take care of restoring pline interpolation settings and position.
I think you can't translate a spline. Only facettes,mesh, solid. However, there are many problem with the last version. I'm continuing to use archicad 11 and the old version of add on. You can do really great things. It's a pity that it does't work. I think we are only two people to use this addon.
Hi Mario
‎2009-03-24 03:58 PM
‎2009-03-24 04:03 PM
mariosmic wrote:No. I do the sweep in C4D. I don't even expect more intelligence in the connection.
What you mean is that you need the point of a spline in c4d translated in GDL to do a sweep volume?
Mario
