2009-01-13 01:05 PM
2009-05-18 09:22 AM
mariosmic wrote:Amazing work!!!
Render in Artlantis with model made with old add on of cinema 4d
2009-05-18 10:07 AM
Amazing work!!!Thank you!!
2009-05-19 12:21 AM
2009-05-28 04:48 PM
2009-05-28 06:21 PM
Peter wrote:
I agree with the above comments! Beautiful design, and a stunning render! Lovely stuff!![]()
Slightly off-topic I know, but I'm curious as to what happens to the model next? I presume the drawings are for planning purposes only as they contain no construction information. How do you now turn this design into a constructable building? Is it just a case of churning out lots of sections, and adding all the detail by hand in 2d, or is there a way to continue to utilise the 3d model to get even basic geometrical data for the beams and so on?
Thanks for posting, anyway!
2009-05-28 06:48 PM
mariosmic wrote:That's a shame. So what happens next to the model? Do you have to do the constructional detailing, or is that someone elses job! Are they going to fully model it again in another program, like Digital Project, or is there another method to do the construction drawings?
When you came back in Archicad the new shape is an Object, so you can have all the characteristics of an archicad object. It's not a bean or a slam. You can't calculate volume and surface because it's an object.
2009-05-28 07:26 PM
Peter wrote:You will add details as a you are using archicad objects. If you need details however you need explode the drawing and add other lines.
2009-05-28 07:43 PM
2009-10-02 10:03 PM
2009-10-02 10:20 PM
mikoaj wrote:There's no solution. It's seem nobody is interested in this plug in. You can use AC11 and the old plug in.
has somebody solution for the triangulaton problem when emporting from cinema to archicad??
