Unfortunately, it is not possible to do it in the Schedule.
What you can do is you can place the generated Schedule on a Layout and add the desired Text on the Layout so as to achieve the desired final result. However, keep in mind that this is a "hack" and you will have to check the position of that Text on the layout if the Schedule is regenerated to make sure it is in the correct position.
