Bidaya
"Total" text in schedules
Hi everyone
I was wondering if there is a way to add the term "total" on the same line as the total value in schedules.
Thanks for reading.
2 Replies 2
Unfortunately, it is not possible to do it in the Schedule.
What you can do is you can place the generated Schedule on a Layout and add the desired Text on the Layout so as to achieve the desired final result. However, keep in mind that this is a "hack" and you will have to check the position of that Text on the layout if the Schedule is regenerated to make sure it is in the correct position.
Bidaya
Thank you Lazlo
too bad because when you export the schedules to Excel it can be interesting to have the "Total" text included...well maybe in a next version...
Best regards.
