schedule 2d plan preview
gotphish001
In googling I found out the 2d preview is 1:50 and doesn't go off plan scale. Is there a way to change this to something other than 1:50? Be great if I could change individual items to be bigger. My problem is my electric panel will be a good size on my prints but then say a 4" led will be just a black dot it's so small and a 2" led, forget about it. It's just a tiny dot.
Nick DiPietro
Cad Manager/Monkey
Autodesk Expert Elite
Archicad 26 Solo USA
https://farkasassociates.com/
You can set the scale of the schedule to what ever you want but it is for the entire schedule.
Just as you do for other views - the scale is saved in the view settings.
You can't change the scale for individual elements (cells).
1 REPLY 1
