translating plans for desktop publishing
I would like to save some plan drawings and a couple of elevations for use in a printed brochure. I have read other queries on this topic and see that saving as EPS seems to be the trick. In Archicad 8.1 how do you save to EPS as it is not in the supported list in save us, nor is it in the publisher list.
I tried zooming in and saving as jpeg but it still blotches out. The graphic designers want me to save as photoshop files but the quality is nothing like the original Archicad version.
Any ideas?
6 REPLIES 6
How about using a printer driver which generates PostScript and specify that the printing output should go to a file?
Ralph Wessel BArch
Central Innovation
Eduardo Rolon
The best option is to print to PDF from either windows or mac OS and Photoshop will open the file and since it is vector drawing (resolution independent) the graphic designer can choose the resolution he wants to work with.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
stefan
Print to PDF or PostScript and you can open it in Illustrator or CorelDRAW or similar Vectorial applications too.
Or in Photoshop, if you don't need Vectors.
Archicad-user since 1998
my Archicad Book
Petros Ioannou
Publish as encapsulated Postrcript from Plotmaker?
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Petros
Yes (at least I assume it is still possible in PM3).
You can also print to a file from most (if not all) Postscript printer drivers. This is standard on Macs; not as common on PCs.
stefan
It usually works on PC too. You can install just one of the default printerdrivers and set it to print to file. The file will be named file.prn and if you change the name to file.ps it is usually a valid PS-file.
I had it happening once that I received a PRN file from a colleague and tried to rename it, but when checking the contents of the file, I noticed that it were valid Postscript instructions, but encapsulated in a HP-specific printcall (PCL-language). But Ghostscript could correctly translate it into a PDF-file.
my Archicad Book
