mitchSyd
use of SURVEY POINT in AC29
I have specified in my IFC Translator the use of the Survey Point
However on export IfcMapConversion and ifcProjectedCRS are not present.
Any suggestions?
PS Is there an AC29 ArchiCAD.pdf to compare with the 27 version.
is there any documentation on changes to IFC in AC29
Operating system used: Mac Apple Silicon 15.7.2 (24G325)
3 Replies 3
You can find the Archicad 29 online help here:
https://help.graphisoft.com/AC/29/INT/index.htm#t=_AC29_Help%2F001_GettingHelp%2F001_GettingHelp-1.h...
About IFC 4.3: it does not say much except that it can now natively read and write IFC4.3 files:
https://help.graphisoft.com/AC/29/INT/index.htm#t=_AC29_Help%2F005_NewFeatures%2F005_NewFeatures-26....
Zoltan Vale
Hi @mitchSyd ,
Could you please attach the problematic IFC in this thread in a zip so that I can have a look at it?
Did you export it as IFC4? Because the above mentioned entities are not available in the IFC2x3 schema.
Zoltán Válé
GRAPHISOFT Product Manager
Zoltan Vale
I have checked the issue, seems that if you save 4.3 schema IFC from AC29 then these don't get exported. It is a bug, I have entered to our database and we should fix it asap, for an upcoming hotfix.
Until then if you save IFC4 then the required entities will be there even from AC29.
Zoltán Válé
