Why is it that a dwg xref'd into a archicad file will remove its created layers after it is removed from a file when a archicad hotlink will not do the same. It seems xref, which is from autocad, has much better control than archicad's own hotlinked method!!! go figure.
Probably because it is very bad practice to have the hotlinked module file have a different attribute set then its host file.
So normally your module file has the same attributes as the host file it is hotlinked into.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
