2003-11-17 10:39 AM
2003-11-17 12:54 PM
2003-11-17 03:14 PM
2003-11-18 04:22 PM
2003-11-18 04:58 PM
Dave wrote:Dave,
Maybe if I had had many different types of objects placed in 8v3 the results would have been different. I haven't checked the libraries to see how many names have changed. If I remember correctly (very possible I don't), library objects changed names often in past upgrades. No?
2003-11-20 06:33 AM
Dave wrote:Since AC 8 was introduced the priority for the program when searching for lib. parts is (in chron. order below):
Piotr's method worked fine--all doors and windows came up in 8.1 exactly like 8v3. I thought the 8.1 library folder naming conventions would screw things up, but the objects themselves all have identical names as the originals in 8v3..... If I remember correctly (very possible I don't), library objects changed names often in past upgrades. No?
2003-11-20 08:44 AM
2003-11-20 10:27 AM
2003-11-21 12:37 PM
2003-11-25 03:04 PM
Jacek wrote:Having used this feature on a number of occasions I have yet to see that it does anything to specific objects (like updating scripts, names, etc.) loaded in your libraries, so I have come to the conclusion that this feature is intended to update libraries located on an FTP server. Can anyone at GS provide some insight to intended function of this feature?
Start AC 8.1 while holding "Command (Apple) - Option keys, this will open the Special menu.
Select the previously saved file and open it.
In the Special menu select "Update Library parts" and let the program upgrade them.
HTH
Jacek
