ARCHICAD equivalent of SketchUp component
In SketchUp, when you make a group of objects into a "Component", you can repeat that Component as many times as possible, and at any time, you can edit one of these Components and all of them will change accordingly (i.e. "Change one to change them all").
What would be the closest workflow in ARCHICAD to re-create this?
6 REPLIES 6
Eduardo Rolon
Read about Modules.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
My understanding of the Modules is you need to access it each time via the Hotlink Modules manager and manually update it each time (as opposed to having it update in real time). Is this correct?
Eduardo Rolon
Basically yes.
The procedure sounds more complicated than it really is since it tries to avoid destroying your CD's because of user error. You also have to take in consideration how you are going to coordinate story levels and if there are going to be mirrored options.
You could also same the object group as a library part and update/reload as necessary but then you would lose the individual items.
AC28 US/INT -> AC08
another Moderator
Erwin Edel
Depending on what it is you are repeating, there are also objects/library parts to consider. These will update instantly, however the 3D elements are no longer consider as wall, slab etc etc and won't behave in such a manner with regards to connections in the model or quantity take off.
ArchiCAD21 'feels' a bit slow with modules, whereas ArchiCAD22 has sped up a bit again. But you are correct that after changing the module you have to update them to reflect changes. In place editing is also a bit cumbersome.
For 'larger' modules, we have reserved space in our model that we exclude from quantity take off where we can edit the elements, select them and save the module file. No need to break module and save it again or edit it in seperate file. However each workflow has it pros and cons and different situations will merit one or the other.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
ejrolon wrote:
Basically yes.
Thanks ejrolon, I'll have a go.
Forgive my ignorance, what's CDs? (CDs to me is Construction Documentation)
Eduardo Rolon
Cortect on CDs being construction documents
AC28 US/INT -> AC08
another Moderator
