Design forum
Best way to ceate a 3D pattern on concrete
Maria_K
Dear fellow Archicad users,
I am modeling a concrete facade for a project. The facade is supposed to have some kind of pattern (see attached picture for inspiration). What do you suggest would be the best way to model it in Archicad for a nice
3D effect?
I have thought about curtain wall or Accessories wall addon using AC profiles.
Any other suggestions?
/Maria
Eduardo Rolon
You can do the same using either the "Window Niche" or the "Opening Tool" and then you don't need to use SEOs, or manage extra layers and if you move the wall they will move with it.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2022
9 REPLIES 9
Hmooslechner
SEO - cutouts with Morph-solids which of which You turn off the Layer of the Morphs later.
AC5.5-AC25EduAut, PC-Win10, MacbookAirM1
Maria_K
Thanks! It's a good idea. Only that it would be a bit time consuming if you have a large wall area and a pattern that requires many morphs
Hmooslechner
To get the pattern easily - you could use the facade-tool instead of single morphs - then SEO the same way...
Maria_K
Which one is the facade-tool?
sorry - curtainwall-tool. in German its called "Fassaden-Werkzeug"
Hmooslechner
like so: https://www.youtube.com/watch?v=5Ws20CFCqlU
Wow, thank you for the video! 😀
Eduardo Rolon
OS X 10.XX latest
AC25 US/INT -> AC08
Vectorworks 2022
Maria_K
I think that probably the best way to do it! Thank you
Didn't find the answer? Start a new discussion
Labels
