Design forum
Contour line resolution in 3D
CIA20
Hello Archicad users,
I just merged a project from AC24 to AC25 and noticed the resolution of my 3D image changed (see the photo attached).
A few years ago, I did have the same problem and don't remember where the setting is to make the edges look like a straight line rather than a sum of short lines.
Thanks in advance for your precious help.
CIArchitecte
Archicad25
I think you are after the Work Environment > Advanced Redraw Options > 3D OpenGL Antialiasing.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Versions 6.5 to 25
Hello Barry,
Thank you for your answer.
I did check the Antialiasing 3D but nothing happened...
Do I miss something?
Thanks a lot.
Irina
It is ok now, It didn't refresh automatically on the layout page.
What you suggested helped indeed.
Thanks a lot and have a great day!
Irina
Didn't find the answer? Start a new discussion
Labels
