If you have a "Custom" library folder then just load that library along with any others as you have been doing.
They call it linking a library now.
If you embed library objects then they are available only to that particular job (the embedded library is contained within the PLN file) and if you make changes to your customobjects they will only change in that particular job (or template if you have one set up).
Should you want to use these embedded custom objects in another file then you have to extract them to an external folder and load that in the other files.
So keep the custom parts in a separate folder and load it as a separate library.
