Design forum
Custom door leaf - file size
Yvonne
Does custom door leaves increase file size?
1 REPLY 1
Yes, because the GDL file is saved (by default) in the Embedded library.
You can go to the library manager, list the files by 'details' and you will see the file size.
Usually a custom door leaf would be a fairly small file I would think, unless it is a very complicated door.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Didn't find the answer? Start a new discussion
Labels
