Is it possible to eliminate the door panel outline that apparently is created by default with a custom door? I've created an arch-topped iron gate, so the rectangular outline is not appropriate. I also want the opening lines referencing the actual gate edges, not the outlining rectangle. (Ignore the door showing behind the gate.)
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.comMBP 16" (M1 Max) 64 GB•OS 12.5.1•AC 26 (latest build)
