2003-11-19 04:47 PM
2003-11-19 11:48 PM
Dave wrote:It is called Favourites.
Is there a way I'm missing to streamline this process?
2003-11-20 06:42 AM
Dave wrote:If you want to "pick up" the setting for a specific existing window/door and then just modify the new window a bit before placing it in plan, you can always "ALT" click on an existing window/door to pick up it's settings and then move along with the refined settings on the new element.
When creating doors and windows, is there a way to shortcut the process?
2003-11-20 08:32 AM
2003-11-20 08:51 AM
Dave wrote:You're absolutely right and you've answered your own question. Standard library treats the different windows differently because they are different library parts. While it can be time consuming in the beginning to setup Favorites, it is well worth it in the long run. It's not that bad though if you do it as you go; create a new window config, save it as a favorite. Four or five windows into the project, and you've probably got a good percentage of the total windows as favorites.
Djordje & Susanne,
Please let me know if I'm missing something, but I don't see how either suggestion addresses the question. There is no real difference between using Favorites or the eyedropper. In either case one has to have the particular object configured prior to placing clones. Parameter settings cannot be shared between separate objects--not surprising if one object is a door and one is a stair--but here we're talking two windows. The problem is that the standard library treats every different window configuration as a separate object rather than one window object adjusted with its parameter settings (a la Theometric).
2003-11-20 10:42 AM
symm wrote:Unfortunately, that's not necessarily the case. With large, new, high-end, custom homes, there can be 100 windows, and sure, there might be 60 windows that are of one type-say double-hung. However, single unit , two unit , and three-unit versions are all separate objects (5-unit versions are not even possible without placing multiple windows side-by-side), as are double-hungs with various transom configurations. Favorites in this case is a work-around. A far better solution (sorry to keep harping on this) is the method Theometric uses. Yeah...I know...so just use Theometric. I suppose I will. I would just like the standard library to get better so I have more options.
2003-11-20 10:47 AM
2003-11-20 11:00 AM
2003-11-26 01:58 PM
Jay wrote:I used to have the same reservations about favorites until the "Woodster" demonstrated at one of his users groups how to save favorites as sets. Now I have separate favorites sets for windows, doors, walls, etc..
I have not ventured into using Favorites. I guess because I figured (once many favorites are saved) it was going to follow the same "hunt and peck" method in finding and selecting library objects.
