Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper-Archicad Import Attribute parameters
RcK
Hey all!
I am just getting familiar with the Grasshopper-Archicad livesync functionality. I have a project in mind I am trying to achieve, but the plugin don't seem to have all the functionality I would need built-in.
The main question is, is it possible to real-time import Attribute params like the dimensions and materials of the layers of a composite element? Currently the only output the composite node has is the composite's name. If i could get the mentioned attributes as a text, i could continue my work.
Thanks in advance.
0 REPLIES 0
