Read more
May I ask about automatic dimensioning
Aye Moh Moh
Hello. Is is possible wall core dimensions by using automatic dimensioning?
It takes time for large numbers of wall by clicking each wall core .🤔
Please share your knowledge to save time for wall core dimensioning.
You can dimension the core faces and/or the reference line, but you can not dimension the core centreline as shown in your image.
The options are in the dimension settings dialogue as you invoke the automatic dimensions.
So, if you reference lines are in the centre of the core, you can dimension those.
Thanks for your answer berry, I wanted to dimension reference line that are in the center of the wall.So it was solved with your answer , checking core faces.
Thanks alot.😊
