Morph editing
i made a morph rectangle and then adjusted its corners in 3d space to create a sort of ramp.
but now the morph is not allowing me to edit any of the corners.
Why is that? i cant select any corner points in 2d or 3d.
4 REPLIES 4
Hello papsphilip,
I think there is an missing information because I never met this kind of mistake
You are able to modify your morph in 2D and in 3D as well
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
As you can see some of the edit tools do not appear.
doesnt matter where i click on the morph, edge, point, surface.
For some reason i am not allowed to move the points.
When I model with morph I always draw all in 2D before pull the shape in 3D. And about a wall I do this kind of it with the wall tool by this option :
Christophe - FRANCE
thank you, i 'll try it when i find the time
Learn and get certified!
