‎2020-08-05 07:30 AM
Solved! Go to Solution.
‎2020-08-06 03:33 AM
Mike wrote:Both.
The hairline setting mentioned, is that in the print dialog when actually printing a drawing, or is it in the publisher settings?
‎2020-08-05 10:51 AM
‎2020-08-05 11:14 AM
‎2020-08-05 01:27 PM
DGSketcher wrote:Well FWIW there
Just to cover all bases, in case you weren't aware, the on screen view options in the top menus will let you switch between hair line and true line weight on screen. This doesn't translate to printed output though.
‎2020-08-06 12:05 AM
Mike wrote:Both.
