Simple opening with shutter
Strawbale23
Hello
Is there a way to create a simple opening in a wall, no window, with an exterior shutter?
Thanks
AC26
https://www.zendsign.fr/
Guru
Which localisation are you using? If you are using INT or ones that use that library, could you use the Rectangular Window Opening? You can turn Sunshades on on them. Or is that the wrong type of shutter? Can you add an image to your post with what you are trying to achieve?
Ling.
ps. Please add a signature. See links in mine for more details.
Win10 | R5 2600 | 16GB | GTX1660
Guru
Ling.
Thanks!
AC26
