2023-02-02 12:26 AM
Hello
Is there a way to create a simple opening in a wall, no window, with an exterior shutter?
Thanks
Solved! Go to Solution.
2023-02-02 02:11 AM - edited 2023-02-02 02:15 AM
Which localisation are you using? If you are using INT or ones that use that library, could you use the Rectangular Window Opening? You can turn Sunshades on on them. Or is that the wrong type of shutter? Can you add an image to your post with what you are trying to achieve?
Ling.
ps. Please add a signature. See links in mine for more details.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win10 | R5 2600 | 16GB | GTX1660 |
2023-02-02 04:16 PM
Thanks!
Subject | Likes |
6 | |
4 | |
3 | |
3 | |
3 |
