Design forum
Skylight
Newbie here...coming over from 20 years with Vectorcrap.
skylight is on second story but is showing up on my first floor plan...for life of me cant find setting to turn it off floor plan!
also trying to get skylight to show up on window schedule...any ideas
3 REPLIES 3
In the Window Schedule > Scheme Settings... > Criteria you'll need to add Element Type is Skylight. But the Skylight's Fields will not match the Window's Fields, so a separate Skylight Schedule may work better.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Skylighs are displayed on the Floor Plan according to the settings of their host Roof/Shell element. Go to the Roof/Shell Settings Dialog in the Floor Plan and Section panel experiment with the Show On Stories, Floor Plan Display and Show Projection Settings of the Roof/Shell. You can also play with the Home Story setting of the host Roof/Shell. You should be able to achieve the desired 2D representation on the various Stories.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Could you tell me the Top 5 reasons you refer to your previous program as Vector....? I am quite familiar with the program so I have my own opinions but I would be interested to hear your experiences. I suppose you have worked a lot with it in real-world scenarios.
Didn't find the answer? Start a new discussion
Labels
