Design forum
UI very slow.
So I have installed Archicad 24 (then also 23) on my brand spanking new Dell Precision 7750 with RTX5000 GPU and I have one very annoying issue.
Some Tools (not all) are very slow to react. 15 seconds for each change. I can do some changes in Infobox, but that's not most efficient.
Ideas?
PS: Nvidia Drivers installed.
9 REPLIES 9
3 things I know of that can affect speed.
Machine specs and local hard drive free space - I assume not a problem in this case.
Make sure that Archicad is using the dedicated video card and not any built in card.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=71672#p320869
Add exemptions to your anti-virus software so it doesn't check anything to do with Archicad.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=59564
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Barry,
Thank you for your reply.
Laptop is plenty powerful and Archicad is using Dedicated GPU.
I'm baffled.
Graphisoft?
Miki,
Could you maybe create a short video clip showing the issue, then upload it somewhere and post a link here? It would be easier to see exactly what is happening in Archicad.
By the way, are you running many other applications besides Archicad? It is equally slow if you have only Archicad running with all other applications closed?
Did you also check into the Anti-virus exemption thing Barry was referring to? That can also make a very big difference in certain cases.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Here is the video with the experience I 'm getting.
https://1drv.ms/v/s!AmTT5KRuRUkhwXezF-Bire9UUqWt?e=CHbBiq
In general Archicad operates fast, it's when I open those Tools windows where is a 3d preview window (at least that's what I think is a common feature) where I get a lag between when the window opens and when I can do something in that window.
I will check with our IT to see if there is something they can do about Archicad exclusions.
It seems to be a problem with the 3D preview but not the actual 3D window.
The 3D preview as far as I know is always OpenGL.
The 3D window does not have to be - but it looks to me as if yours is as I see a faint repeating image on the walls.
Try this setting in the Work environment to see if it makes any difference.
Otherwise I think 23 & 24 need a newer version of OpenGL.
You mentioned you have Nvidia drivers installed, but are they the latest ones?
Versions 6.5 to 25
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
HI Miki,
Thank you very much for the report and I am very sorry about the issue!
This is a rare one, I must say. Looking for a similar report, I only found one case which has the following reproduction steps:
1. open the 3D window, unhide all layers
2. close 3D window/tab (it is not enough to switch away from it!)
3. open the Beam settings dialog
On first use, a texture is added to the used texture list (in modeler attributes) and it stays there until the plan is closed. Whenever the first OpenGL view (3D window or preview in the settings dialog) is opened, those textures are loaded no matter if they're actually used in the scene. When the last view is closed the textures are unloaded. The problem is if the preview is the only OpenGL view, all textures are loaded/unloaded after every change.
The workaround for this is to keep the 3D window open to prevent the texture from loading/unloading.
This happens if there is a texture in the file. I'm wondering if that's the case? The workaround is to use smaller textures and using jpeg instead of png.
Which leads us to the next question: does this issue also happen when starting a new file with the default template?
I haven't seen it mentioned before, but make sure that Archicad is updated also!
Please let me know how it goes!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
I want to provide update on this issue. Our company installed SentinelOne (antivirus) update and it has caused those issues. It has affected few other tools that rely on OpenGL. They have a a fix for that.
Thank you for your help.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Miki,
Thank you for the information! It's very rare to see antivirus software affects the OpenGL environment. Anyhow, I assume the problem is solved now?
Have a great weekend!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
I know this is an old post. Just wanted to confirm that the issue persists in AC26 in the 3D preview of beams and columns within the dialog box for those tools.
The workaround still works: As long as the 3D window is open, the beam/column dialog box does not lag.
Thank you for posting the work around.
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
Didn't find the answer? Start a new discussion
