How detailed are the columns?
Can you show an image from 3D and elevation?
By converting to 'forms' I assume you mean 'morphs'.
This probably won't make too much difference as the resulting morph will have just as many polygons.
However, being a morph you are able to reduce the number of polygons.
The problem with this is it may change the look of the column as it won't be as detailed any more.
Take a copy of you file and try converting to morphs and reducing the number of polygons (segments).
There is no harm to your original file if you experiment on a copy.
Then if it works you can save it back as your original or go back to the original file and do the same changes may be better just in case you have messed something else up in the experimenting.
