importing library objects from other software
hello,
I apologise if this has already been answered but i have tried finding an answer...
is there a simple way to import an existing model in a format such as obj or 3ds and use it in the object library?
the same way you would download a furniture item or similar?
thankyou
6 REPLIES 6
You could try Model Port.
Hope that helps.
It is sad that it is sold only as a yearly subscription ;(
Piotr
Nader Belal
Mentor
@Braza
If you have Rhino, you may open your files there first then use Grasshopper-ArchiCAD connection for automatic translation.
Model Port for that type of operations is better for beginner users, and its yearly subscription is not that high if you tend to convert a big number of objects to GDLs (just think on all the time you will save).
By the way, Sketchup can import 3ds.
Eduardo Rolon
So can AC
https://helpcenter.graphisoft.com/knowledgebase/64526/
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Nader Belal
Mentor
@ejrolon,
Thanks, I was going to write that
If the 3ds model to import has good UV mapping - then the 3ds format gives the best reasults of all foreign formats.
(but some vendors may have low quality model for architects...and so that models cause problems)
Piotr
Learn and get certified!
