Archicad C++ API
An issue that attribute index value of layers created by API is different from layer setting dialog
Ryo-H
Is there a way to make the index value of a newly created layer or layer combination the same as the layer setting dialog? If missing indexs are in layers (for example, layer attribute indexs are 1, 2, 5 and 6, and 3 and 4 are deleted), ACAPI_Attribute_Create outputs a new layer's API_Attribute structure with index is 3.
If a newly created layer by the layer setting dialog, it had index is 7, different from the ACAPI_Attribute_Create outputs. The same was true for the layer combinations. This difference may cause layer item conflict issues between teamwork users.
Akos Somorjai
Hi Ryo,
There's no direct way from the API; you have to create temporary attributes to fill in the holes.
Best, Akos
Akos Somorjai
Hi Ryo,
Best, Akos
Thank you for your reply. I'll try it.
