Archicad C++ API
Archicad API Download Problem
Botonis
Still the API download is not possible...for more than a month.
Any news about this?
Greetings
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
12 REPLIES 12
Could you say what is not working?  I just clicked the big blue download button and it seems to work fine.  Is your issue with an earlier release?  Have you tried different browsers?
One of the forum moderators
Botonis
I cannot register as developer. There is no option available. I contacted the dev team and they have no idea when they will fix it. Is there any other way to download it...?
Botonis Botonakis
Not being able to register is different from not being able to download.  Only registered developers have access to the developer kits.
You have a Graphisoft ID - which is what you used to sign in here (and for your product).  What happens when you use that Graphisoft ID to attempt to sign in on the developer site here:
https://archicadapi.graphisoft.com
Botonis
Botonis Botonakis
hascdev
I have the same problem!! don't see the developer tab
Botonis
two months..................
Botonis Botonakis
Did you fill out the registration form?
https://archicadapi.graphisoft.com/registration/personal
hascdev
Yes, of course, tab personal and billing is complete!
akomporday
Hi Botonis and Hascdev,
I'm very sorry for the late response. There were some technical problems on our site, but now you should see the development kits. Can you please confirm whether the issue is solved?
