‎2021-01-07
03:58 PM
‎2021-09-14
01:32 PM
Noemi Balogh
Solved! Go to Solution.
‎2021-01-11 09:15 AM
‎2021-01-08 01:25 AM
runxel wrote:
Hey there, found another bug:
GLOB_WORLD_ORIGO_OFFSET_X (and _Y) always return 0 (zero).
Tested with AC 23 and 24.
‎2021-01-08 10:11 AM
add2 -GLOB_WORLD_ORIGO_OFFSET_X-SYMB_POS_X, -GLOB_WORLD_ORIGO_OFFSET_X-SYMB_POS_Y
line2 -0.1, 0.0, 0.1, 0.0
LINE2 0.0, -0.1, 0.0, 0.1
hotspot2 0.0, 0.0, 1
text2 0, 0, "( 0.00 ; 0.00 )"
text2 0, 0.5, "World Origin"
del top
if abs(GLOB_WORLD_ORIGO_OFFSET_X) > 0.01 or\
abs(GLOB_WORLD_ORIGO_OFFSET_Y) > 0.01 then
! THIS WILL NEVER BE EXECUTED
add2 - SYMB_POS_X, - SYMB_POS_Y
line2 0.0, -0.1, 0.0, 0.1
hotspot2 0.0, 0.0, 2
text2 0, 0, "(" + str(GLOB_WORLD_ORIGO_OFFSET_X, 9, 4) + "; " + str(GLOB_WORLD_ORIGO_OFFSET_Y, 9, 4) + " )"
text2 0, 0.5, "Virtual Origin"
del top
endif
if abs(GLOB_WORLD_ORIGO_OFFSET_X + SYMB_POS_X) > 0.01 or\
abs(GLOB_WORLD_ORIGO_OFFSET_Y + SYMB_POS_Y) > 0.01 then
hotspot2 0.0, 0.0, 3
text2 0, 0, "(" + str(GLOB_WORLD_ORIGO_OFFSET_X + SYMB_POS_X, 9, 4) + "; " + str(GLOB_WORLD_ORIGO_OFFSET_Y + SYMB_POS_Y, 9, 4) + " )"
text2 0, 0.5, "Object Placement"
endif
‎2021-01-11 03:15 AM
needs to be ...if abs(GLOB_WORLD_ORIGO_OFFSET_X) > 0.01 or abs(GLOB_WORLD_ORIGO_OFFSET_Y) > 0.01 thenAll on one line and the "/" removed after the OR
‎2021-01-11 05:08 PM
Peter wrote:THAT was the missing piece of information...
This offset is only recalculated when a file is opened, so it might look it isn't working with a moved object.
First move the object far away from the origin, save the file, re-open it, and the extra hotspot will be visible.
