Archicad C++ API
Issue with getting the opened project's name
I'm trying to get the current opened project's name. Here is my code, which should work according to the documentation, but it doesn't seem to work:
GSErrCode            err;
    API_ProjectInfo info;
    err = ACAPI_Environment (APIEnv_ProjectID, &info, nullptr);
    if (err != NoError){
        ErrorBeep ("APIEnv_ProjectID", err);
    else{
        WriteReport("project path is %s", info.projectPath); // returns null always
        WriteReport("project name is %s", info.projectName); // returns null always
Is there any other specific thing that should be done in order to make this work? Is the project name something different than the filename of the pln?
P.S. I am opening an already saved project.
Any help will be appreciated,
Julian
I have tried printing the untitled property:
WriteReport("project untitled is %s",(info.untitled)?"true":"false"); // returns false always
Why it says that the file is not saved? I'm opening an already saved project.
Mihaly Palenik
Unfortunately this is a bug. We will try to do the best to fix it as soon as possible.
Best,
Mihály
