2020-11-30
04:17 PM
2021-09-15
09:29 AM
Noemi Balogh
2020-12-01 02:46 PM
n = REQUEST ("Name_of_line_type", index, name)But I think you can't query the used lines from the labeled element.
2020-12-01 04:05 PM
2020-12-02 05:30 PM
DGSketcher wrote:It was a bad idea, I didn't think about lines can't be labelled associatively.
Thanks, I found that but I can't see a query option that would work with drawn 2D lines. I am trying to develop a suggestion by Peter Baksa that we can use the Linetype name to display associated values in a label. On plan you can use the Morph line but you can't use Morphs in a Detail window, which is where I need to place the label.
2020-12-02 06:26 PM
