Archicad C++ API
TEXTBLOCK lines height adjustment
pedrocollares
I've been putting up a custom schedule in GDL to list finishes of a project out of surfaces, and it seems to be working all fine, but I would like to have the text block lines a bit closer to each other.
Is there a height factor to be applied to text blocks? I couldn't find such thing in the reference guide.
Thanks in advance!
Architect / BIM Manager at IDEIA1 - www.ideia1.com.br
Archicad 26 / Windows 10 64
4 REPLIES 4
DGSketcher
Legend
See if these links help...
Creating a Label Text with AC Globals
Parameters for Text Handling
Line spacing is controllable in the Paragraph command
It is not in the textblock but paragraph definition and it is called line_spacing there:
http://gdl.graphisoft.com/reference-guide/inline-attribute-definition#TEXTBLOCK_gdlcommand
pedrocollares
Oh right. Then I assume I should use paragraph instead of textblock to be able to control that. I can't see how I define the paragraph's width, though. I'm using textblock because I need to restrict the width of the text to have an automatic line break.
You _are_ using paragraphs when using textblocks  😉
